As I understand from before...Lense effect will not show up if render out as .exr format, is this fixed already in Vray 3.5 version?
lense effect not show when render out as .exr format, is this fixed already in Vray 3.5 version?
For versions 3.5 and later we store the lens effects and denoiser result in a separate element called Effects result. This means that if you use multichannel EXR then this channel will be part of your EXR file. But if you use the Save separate render channels option then you will get another channel saved together with the RGB named RGB_color.
