I have six houses that I need to copy about 100 times. Is it best to X-Ref the house, which I have never done, or proxy them? Proxy, to me, is easier. Now, I have the six houses in one scene, so I can just select the house, export as the proxy and then copy.
X-Ref vs Proxy
X-Ref vs Proxy
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090 X2
- Windows 11 Pro
Tags: None
Proxy so it consumes less resources. Xref is mostly when others work in that scene same time and u dont have to import after every update. Im not sure if xref saves u any resources though, i think not it has another purpose than proxies.
I am banging my head! Creating a proxy of the whole house loses its texture and if I attach everything first my mapping gets screwed up.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I am working some time now with Smartrefs on a huge project. Take a look at it and try it out. I won't work without it anymore, so really worth a look. In your case you make 6 Smartrefs, each with it's own Smartproxy and copy/instance(/even change) these around in your master scene a much as you want.Last edited by trick; 22-12-2017, 04:31 PM.
Originally posted by trick View PostI am working some time now with Smartrefs on a huge project. Take a look at it and try it out. I won't work without it anymore, so really worth a look. In your case you make 6 Smartrefs, each with it's own Smartproxy and copy/instance(/even change) these around in your master scene a much as you want.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I have my scene with 6 houses. I have each house referenced in using SmartRefs and I have a proxy for each one, to be used in the viewport. All are great, but how do I copy these buildings around my scene? I would like each copy to also be displayed as a proxy in the viewport, but render using the referenced house. I am stuck. Although everything thus far is cool, I really need to copy the houses around, like I would with a normal v-ray proxy.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Hi Bobby,
I think you need to contact Felix (Developer) directly for faster results. He is very helpful. I have been working with SmartRefs in combination with Sini Proxies and VRay proxies and use large sceneparts as SmartRefs. Inside these scenes I have been instancing the buildings as Sini Proxies to avoid attaching everything together in one VRay Proxy. I thought that in SmartRefs one can do something similar, but you can only make a proxy for a complete scene. However: when using a proxy for a SmartRef scene, behaviour is strange and unexpected once you start copying/instancing either the SmartRef Proxy or the SmartRef itself inside the master scene. So I am contactting Felix about this myself. For now, in your case, it might be better to use Sini Proxsies. Sorry for the confusion, but in the last months, I have been (and still am) looking for the best solution for these kind of projects myself.
Yeah, I have found the strange behavior, too. It seems that SmartRefs is good at what it does, but not for what I need.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Hi, I usually can make it work by using the script "quick attach" on my multi-part object. It merges everything and automatically creates the proper multi-material. Then I export that as a proxy and just reapply that multi-material to it and all the textures are in the right places. I'm not sure the reason it didn't work for your houses but this is what I do!
Using MAX's proxy system caused my displacement not to work, which was strange. I could attach everything and merge the materials and reapply, but my displacement broke.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostYeah, I have found the strange behavior, too. It seems that SmartRefs is good at what it does, but not for what I need.
I prefer the Smartrefs solution. Eventually you should be able to make 100's of copies of a house, use proxies to represent them and still assign different materials without the memory overhead of the 100 houses. Often in birds eye views, when there are multicolored roof tiles, you can clearly see the tiling because of these roof tiles, when you have lot's of instances of the houses. There should be a memory friendly solution to solve this problem,without having to use mesh proxies, which you can not edit in the master scene (like VRay or Sini proxies).Last edited by trick; 23-12-2017, 10:22 AM.
Please, tell me I can join and keep vray displacement. When I join or proxy I lose my displacement, but I am sure I have made proxies of trees with displacement and they stayed.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Okay, you can't have v-ray displacement and proxies, which stinks. I can't use MAX's displacement, because of my corners, so it seems that X-Ref and Instances is the only solution.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I am literally back where I started. Since I work alone, not in a team environment, there is little benefit in using X-Ref's. Basically, now I group and instance.Bobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by glorybound View PostI am literally back where I started. Since I work alone, not in a team environment, there is little benefit in using X-Ref's. Basically, now I group and instance.
https://docs.chaosgroup.com/display/...+%7C+VRayScene
But I have used it to better results, faster and more stable than X-Ref.
Merry X-Mas!
