Is there a way to render the wireframe color using VRay EdgesTex?
  • Is there a way to render the wireframe color using VRay EdgesTex?
    Not a str8 solution but, with vray edges textures b/w and 1 wire color element is possible in compositing. Just mask the wire color with the b/w edges one. cheers
    www.yellimages.com
      Thanks for the idea
        If you want to solve this in another way you can look into custom parameters of objects (Object properties --> User Defined). You can get the wirecolor in a variable there per object (script it to loop over all your objects and fill the variable) and then use the VRayUserColor node to drive the EdgesTex color.
        Software:
        Windows 7 Ultimate x64 SP1
        3ds Max 2016 SP4
        V-Ray Adv 3.60.04
        Hardware:
        Intel Core i7-4930K @ 3.40 GHz
        NVIDIA GeForce GTX 780 (4096MB RAM)
        64GB RAM
        DxDiag
