save file question
  • save file question
    Hi, i have doing a animation recently, may i know can i save (vray raw image file) with denoiser in EXR format, and the same time can i use the (seperate render channel) save to save other render passes like vraylight, vrayreflection in TARGA format?
    Jackie Teh
    3ds Max 2023, V-Ray 7 Hotfix 2 [7.00.08 build 00000]
    AMD Ryzen 9 7950X 16-Core Processor@4.50 GHz | 64GB RAM | Nvidia RTX 4090
    Website: https://www.sporadicstudio.com
    Email: info@sporadicstudio.com
    YouTube: https://www.youtube.com/c/SporadicStudio
    The only way i know how and the way we do it here is with a postrenderframe callback script. check the docs here:
    https://docs.chaosgroup.com/display/...ogrammatically
      You can set the regular 3ds Max output as JPG file, and enable the raw VFB output to write a vrimg or a multichannel OpenEXR file.
        Unfortunately that method doesn't give you all the passes just the RGB colour.
