Displacement Modifier Question
  • Displacement Modifier Question
    I haven't used the disp modifier in the past, and trying to use it now. Every time I render, it crashes max. I've gone through the help file but can't see anything wrong. Are there any standard workflows for the displacement?
    In most cases, the default settings are good enough.
    If you want, you may send us your scene along with all assets used in, so we can check your setup and investigate what is the reason for the issue.
    Hristo Dimitrov | chaos.com
    Chaos Cosmos Representative | cosmos.chaos.com
      What are you using, 2D or 3D and what kind of map are you using for the displacement itself?
      A.
      www.digitaltwins.be
        I'm 99% sure you just set settings that make your RAM explode and max crash
        Software:
        Windows 7 Ultimate x64 SP1
        3ds Max 2016 SP4
        V-Ray Adv 3.60.04
        Hardware:
        64GB RAM
        DxDiag
