Does anyone know why my slave will not complete a bucket? I let it run all night and every bucket from the slave just sits there with no activity on the CPU or RAM? I don't get any error messages and I think my license is working.
Stuck Buckets
Stuck Buckets
Bobby Parker
www.bobby-parker.com
e-mail: info@bobby-parker.com
phone: 2188206812
- 128gb Vengeance RGB Pro RAM
- NVIDIA GeForce RTX 4090
- Windows 11 Pro
Tags: None
Just a shot in the dark. If this was a scene that uses psd-manager - then make sure you install the plugin also on the slave (no license is needed for network rendering BTW).
DanielDaniel Schmidt - Developer of psd-manager
Originally posted by dans View PostJust a shot in the dark. If this was a scene that uses psd-manager - then make sure you install the plugin also on the slave (no license is needed for network rendering BTW).
DanielBobby Parker
phone: 2188206812
- Windows 11 Pro
Originally posted by ivan.slavchev View PostIt doesn't look like a license issue. Can you attache vraylog.txt (located in %TEMP%) from the slave?
Also - which V-Ray build and 3dsMax version are you using?Bobby Parker
phone: 2188206812
- Windows 11 Pro
It looks like it was PSD Manager. Now, I am getting dark buckets on the slave. I can't launch MAX on the slave because there isn't a graphics card. The dark ones are the slave.
1 PhotoBobby Parker
phone: 2188206812
- Windows 11 Pro
Seems to be a mapping problem. What I am doing is, I am mirroring the project folder, so my workstation and slave have the same path. In this case, the folder structure is C:\Project Folder\Whole House, both having identical files. I tried both UNC and relative, but it doesn't make a difference.Bobby Parker
phone: 2188206812
- Windows 11 Pro
I think I got it. I didn't reboot after setting things to UNC.Bobby Parker
phone: 2188206812
- Windows 11 Pro
