MAX 2019 1.1 Spline
  • MAX 2019 1.1 Spline
    Anyone having performance issues with splines in MAX 2019 1.1? I mean, so bad I can't work. Picking a spline takes minutes and deleting it another couple minutes. Shapemerge, convert to mesh and select poly picks random poly's across the shape.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Not just spline - https://www.youtube.com/watch?v=bvuwN_5ib-s
    Bobby Parker
    phone: 2188206812
    • Ryzen 9 5900x CPU
    • ​Windows 11 Pro
      Also, merging seems to be broken. It takes a couple minutes to merge even the smallest of things. Could just be me, so if someone can verify, that would be great.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I found out the problem with merging. If the file you are merging is in a different unit, it doesn't work. At least that is my finding. And it seems that the file you are merging things into has to be a larger file. I can merge anything, regardless of scale, into a blank MAX scene.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Bobby,
          I have not upgraded to 2019 should I just skip this release? Seems very buggy?
            Originally posted by gadzooks View Post
            Bobby,
            I think this is something you have to try and see for yourself - there are so many variables out there, equipment, drivers, OS, operator experience and handling, model origins (i.e. where things have come from), scripts etc etc.
            I'm no big defender of AutoDesk's track record with 3DS Max.
            I've found 2019 to be very good.
            Jez
            3DS Max 2023.3.4 | V-Ray 6.10.08 | Phoenix FD 4.40.00 | PD Player 64 1.0.7.32 | Forest Pack Pro 8.2.2 | RailClone 6.1.3
            Windows 11 Pro 22H2 | NVidia Drivers 535.98 (Game Drivers)
            Asus X299 Sage (Bios 4001), i9-7980xe, 128Gb, 1TB m.2 OS, 2 x NVidia RTX 3090 FE
            ---- Updated 06/09/23 -------
              That's why I'm still on 2016 (and 2018 on projects that require more advanced texturing). I can't use 2019 at all because of the decimal point bug. I can't decide which is worse, 2017 or 2019. 2016 has been rock-solid for a 3rd year now. Looks like 2016 is the best versions to use at the moment. 2018 is kinda ok if you don't mind the occasional viewport glitch bugs where suddenly objects can't be selected or completely disappear altogether. Price for upgrades should be decreasing each year, not increasing...
              Aleksandar Mitov
              www.renarvisuals.com
              office@renarvisuals.com
              AMD Ryzen 9 9950X 16-core
              96GB DDR5
                I pay quarterly and every quarter it has gone up. Yeah, something happened after MAX 2016 and I would love to know what. MAX 2018 was pretty good and MAX 2019 is about the same. Being told to convert everything to an edit mesh, not an edit poly, is a joke. Since when can't we use edit poly? Someone should really look into a class action lawsuit. I have lost some much money in lost productivity, it is irresponsible of them.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
