Vray NEXT - registering vray spawner as service fails to start spawner
  • Vray NEXT - registering vray spawner as service fails to start spawner
    i am writing this because i cant seem to be able to run spawner as a service.
    In other words i need the spawner to work (be active or idle) even when i log out ow Windows.
    Registering spawner as a service doesnt do a thing and when a DR job is ran, the node doesnt get picked up. I need to start the spawner manually.
    Then whenever i log out, the spawner closes.
    Any idea what i am doing wrong please?
    Cheers
    M
    Martin
    http://www.pixelbox.cz
    Which Windows version are you using?
    Does it make a difference if you run the service with your account versus using a Local system account?
    You can try in CMD
    netstat -ano | findstr 20204
    and see if you will see the service listening on the port. Normally it takes some time to start (a couple of minutes), depending on your machine
    C:\Users\Ivan>netstat -ano | findstr 20204
    TCP 0.0.0.0:20204 0.0.0.0:0 LISTENING 3128 (this is the PID)
    Ivan Slavchev
    SysOps
    Chaos Group
