Vray Slow stop
  • Vray Slow stop
    I have problem with Vray interactive. It's very slow for stop. I lost about 3-5 mins with every scene when click Stop interactive mode. It happens with vray next and 3.6 too.
    My PC is dual 2670 v0. Is it problem?
    Thanks
    I get this happening too, especially on our larger scenes.
      Hello,
      Could you share the vraylog.txt file from one session with such slow stop ? Or even better - a scene that reproduces it so we can check what is going on ?
      Also - do you have many proxies in the scene and maybe some of them instanced with VRayInstancer or with plugins like ForestPack?
      Yavor
      Yavor Rubenov
      V-Ray for 3ds Max developer
        Originally posted by yavor.rubenov View Post
        Hello,
        Yavor
        Yes, this usually happens when I have a lot of ForestPack proxies in my scene.
          For the proxies case here is a possible workaround:
          https://forums.chaosgroup.com/forum/...unfreezing-max
          Yavor Rubenov
            Hello,
            Yavor
            Thank you and where i can find vraylog.txt?
            It happens with all case. Interior without forest or Vrayinstancer...etc. I think it's problems of vray or my hardware, not my scene.
              The vraylog.txt is located by default in your temp folder - write %temp% in the address bar in windows explorer.
              Yavor Rubenov
                [2018/Aug/3|07:57:33] Compiled with Microsoft Visual C++ compiler, version 19.12
                [2018/Aug/3|07:57:33] Host is 3ds Max, version 19
                [2018/Aug/3|07:57:33] V-Ray DLL version is 4.01.03
                [2018/Aug/3|07:57:38] [VRender] Constructor entered.
                [2018/Aug/3|07:57:38] Setting default filter kernel.
                [2018/Aug/3|07:57:38] [VRender] Constructor done.
                [2018/Aug/3|07:58:09] Resetting VRender.
                [2018/Aug/3|07:58:09] Setting default filter kernel.
                It's here .
                  The log gets overwritten every time you start Max - so could you open a problem scene, start IPR, stop IPR, close Max and then get the log file ?
                  Yavor Rubenov
                    Do you have an email? It's very long so i think i will send it by email.
                      You can zip it and it should compress very well. You can mail it to me at yavor.rubenov at chaosgroup.com
                      Yavor Rubenov
                        Thank you i sent it to your email.
                          Thank you for the log.
                          So far I can't seem to find a problem in the log - it looks like you start IPR at 17:33:17, do a bunch of changes and then stop at 17:39:55, V-Ray does its cleanup and at 17:39:58 it is done ?
                          Yavor Rubenov
                            It still happend with me. I will try test with more file and report with you. Thanks
