Vray NEXT: Impossible to delete nodes in slate material editor when IPR is on
  • Vray NEXT: Impossible to delete nodes in slate material editor when IPR is on
    this has been happenning for quite some time with the newest release and previous one too. When IPR is on , youne basically not able to delete a node in material editor, it stay there and it makes the material creation very messy and inefficient especially with complicated materials. Can you guys please fix this?
    When you go back from ipr to normal rendering mode, you can then delete the node normally.
    thanks!
    M
    Martin
    http://www.pixelbox.cz
    Yep we have the same issue. Very annoying. Not sure if its a max or vray thing though....
    Nick Martin
    ScreenAge - 3D Visualisation
    www.screenage.com.au
      Well this is not doing when i use Corona so it looks like this one is on Chaos end.
      In some cases its almost impossible to use material creation when IPR is on due to the clutter between all the used and unused nodes.
      Hopefully this thread will get picked up soon by the support.
      Martin
        Nothing from Chaos support?
        Martin
          I think it's a max thing because I have it sometimes and I don't use IPR. What helps is minimizing and maximizing Max a few times, and show desktop a few times (windows + D). If not fixed try a few times again. I alternate a bit, most of the time it's fixed, very strange bug though.
          A.
          www.digitaltwins.be
            Same issue here.
            Aleksandar Mitov
            www.renarvisuals.com
            office@renarvisuals.com
            AMD Ryzen 9 9950X 16-core
            96GB DDR5
              Any news about this? It's extremely annoying to keep tabbing in and out of the Material editor every few seconds when working on materials with IPR running.
              Aleksandar Mitov
              96GB DDR5
                For me even shutting down ME doesnt work
                Martin
                  I'll see what can be done for the Next Update 1.
                  Peter Matanov
                  Chaos
                    Happen in IPR too, but for me reopening slate editor fix this issue immediately, dont even need to restart IPR.
                    AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
                    2D | 3D | web | video
                    jiri.matys@gmail.com
                    https://gumroad.com/jirimatys
                    https://www.artstation.com/jiri_matys
                    https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
                    https://www.instagram.com/jiri.matys_cgi/
                    https://www.behance.net/Jiri_Matys
                    https://cz.linkedin.com/in/jiří-matys-195a41a0
                      Hi there,
                      Is this problem solved?
                      I am still having this issue.
                      for my blog and tutorials:
                      www.alfasmyrna.com
                        I'm afraid not. It still happens for me too. Hopefully this can be resolved soon.
                        Aleksandar Mitov
                        96GB DDR5
                          Yep, can confirm... also another bug, if IPR is running and a 3dsmax autosave occurs (either default or from a custom script) it crashes max after the saving is done... This only happens with Vray and no other renderer while running an IPR.
                            I have a similar thing happen to me, but not in exactly the same way. For me it crashes when IPR is running, an autosave happens and I close the VFB window while autosaving. I'm not sure if it's a Vray thing though or just 3ds max being wacky as usual.
                            Aleksandar Mitov
                            96GB DDR5
                            • #15
                              Hello! I've made a note in our bug-tracking system to raise the priority of the issue(internal number VMAX-7435). Regarding the the crash with auto save, I haven't managed to reproduce it and I've tried with and without closing VFB. Does it happen with any scene? Could you share a crash dump and vraylog file? If it happens with specific scene, sharing a scene would be helpful as well.
                              Tanya Todorova
                              QA
