Panorama rendering except spherical panorama and cube 6x1
  • Panorama rendering except spherical panorama and cube 6x1
    Hi everyone,
    I have been trying to render a panorama image that look like the image below
    however, i can only render an equirectangular image with "spherical panorama" or angular boxy image with "cube 6x1"
    whenever i tried to use "cylindrical (point or otho)" the render comes out as a blank white image.
    Is there any way to do that cylindrical rendering or software that transform equirectangular to that cylindrical image above?
    I have also tried "Flexify 2" plug in for photoshop but still can only stick to full sphere and cube.
    Will really appreciate if anyone can solve this problem for me. Have been trying to find an answer for months.
    THANK YOU!!
    Try using Cylindrical with FOV=360.
    Peter Matanov
    Chaos
      Originally posted by slizer View Post
      there's cylindrical (point) and (otho)tried it with FOV 360 before but it came out with a blank light blue rendering. does the resolution size matter? since i used image aspect: 2.0 for sperical panorama and cylindrical
        Sorry, forgot to mention - use Ortho. The aspect ratio depends on what you will be doing with the image after that, but 2 seems too small.
        Peter Matanov
        Chaos
          does the cylinder height matter? what number should i put if i am doing a FOV 360 cylinder?
          It still come out with a light blue image with otho (FOV 360) (cylinder height: 180) aspect ratio 6
            Can you send me the scene?
            Peter Matanov
            Chaos
              I have sent you an email to peter.matanov@chaosgroup.com
              Thanks!!
