VrayVolumeGrid doesn't display PhoenixFD smoke simulation
  • VrayVolumeGrid doesn't display PhoenixFD smoke simulation
    I have a simple smoke simulation in PhoenixFD 3.11. It works and renders well. If I create VrayVolumeGrid in 3.60.04, and load the same sequence PhoenixFD renders into VrayVolumeGrid, I see nothing at all despite the VrayVolumeGrid settings being set up identically to the Phoenix grid. When I load the .aur sequence into the volume grid, I see that the green grid extents show up, the frames appear as loaded, and the frame stats match up correctly, displaying proper cell count and correct channels. Yet, nothing is actually displayed in the viewport, and nothing renders either. Toggling GPU preview on or off changes nothing either.
    I will be thankful for any tips to solve this.
    there are pre-made rendering presets (rendering rollout) which you can load depending on the caches you use. On the other hand, you can export such a preset from Phoenix grid and load it in Volume grid. That's should work
