Can we have an update to VRay GPU NEXT so we can use current GPU drivers.
  • Can we have an update to VRay GPU NEXT so we can use current GPU drivers.
    Hi
    Can we have an update to VRay Next so that we can use the latest NVidia GPU Drivers? Having to roll back several driver versions just to render with VRay is not optimal for other GPU render software that works fine with latest drivers.
    Thanks
    You can use new drivers just fine with V-Ray GPU. It is not update problem. The problem is that most of the new drivers had bugs that were causing issues during rendering.
    We just warn about those in the log, but you can ignore the message and use whatever you like.
    Best,
    Blago.
    V-Ray fan.
    Looking busy around GPUs ...
    RTX ON
      "error: Checking CUDA driver version: Driver 398 does not work with V-Ray GPU. Suggested driver is 388."
      Ahh thanks ok. The log message says it does not work, I have been working around the issue with old drivers for a month now because of that error.
      Can I suggest a change?
      "warning: CUDA driver version nnn has not been approved. Approved driver is nnn"
        Yeah, I guess the message is indeed misleading. We will change it. Thanks for the pointer!
        Alexander Soklev | Team Lead | V-Ray GPU
