VRay zDepth + After Effects Problem
  • VRay zDepth + After Effects Problem
    Hi gang;
    I must be doing something wrong here. In the past, I have always rendered the zDepth as separate sequence but I understand that is not necessary when using a format like EXR as it can be embedded in it.
    So I switch to VRay RT
    I add the VRay zDepth render element and set up the settings
    I render the image in the VRay frame buffer and if I switch to the zDepth channel in the top-left dropdown menu I can see it there
    I save the image as an EXR and make sure to add the VRay zDepth in the OpenEXR save settings under the Render Elements section. I also click on enable for the VRay zDepth layer underneath that
    I save the EXR and I bring it into After Effects, make a comp and add the EXtractoR plugin
    In the R,G,B where I'm supposed to be able to select the Z channel, it does not exist
    What am I missing here? Any suggestions?
    Thanks,
    -Rich
    Richard Rosenman
    Creative Director
    http://www.hatchstudios.com
    http://www.richardrosenman.com
    I believe I solved this.
    It seems to save an EXR with render elements from the VRay Frame Buffer, I need to enable the "V-Ray raw file" option and specify my save filename there. I brought that file in and was able to successfully pull the zDepth.
    So understanding this, when rendering an animation sequence, I no longer specify a save filename from the 3ds Max Common render dialog? It is all done now through the VRay frame buffer using the "V-Ray raw file"?
    Can anyone confirm this is the correct workflow?
    Thanks,
    -Rich
    Richard Rosenman
    Creative Director
      Hey, ive been using vray raw file to save animationfiles with layers fo ages works great
      Martin
      http://www.pixelbox.cz
