White Speckles / Noise
  • White Speckles / Noise
    Any tipps or hints for reducing the noise?
    normaly my machine (HW see signature) would clean this up in less than 2 hours, here i guess its a light in the scene what causes this....
    vray 3.60.03
    BF+LC / Progressive
    2:1 4096x2048 (120min) reaches only around 40 Passes!
    Thanks in advance for any tips.
    Greets Phil
    WS
    DUAL E5-2683 V3 28c/56t @2,6Ghz
    64GB Ram
    ASUS ROG STRIX OC 1080ti
    PALIT SUPER JETSTREAM 780ti
    Node
    I7 2600K @4,40GHZ,
    32GB RAM
    Hello,
    The reason for this could be if a VRayLightMtl is used with Direct illumination - ON. Nevertheless, can you send the scene for investigation?
    Philip Shounev
    QA department
    Chaos
    philip.shounev@chaos.com
      Ok, thanks i will check that! the problem is the scene is quite heavy and uses a lot of xrefs ~ asset colletc will end up with ~ 10-20gb. i'll go through the lightmtls with vmc quick!
      thanks
      Greets Phil
      WS
      64GB Ram
      Node
      I7 2600K @4,40GHZ,
      32GB RAM
        Hy! I managed to clean up the whole scene again:
        i found standard mtls / from merged models
        lights where totaly off with default vaules
        exposure was incorrect so i boosted noise
        it takes me a whole day but ive learned a lot about the „lumen“ workflow
        case closed!
        thx
        Greets Phil
        WS
        64GB Ram
        Node
        I7 2600K @4,40GHZ,
        32GB RAM
