matte/mtlwrapper and lightcache
  • matte/mtlwrapper and lightcache
    Hi all,
    i have a prblem with matte/mtl wrapper and lightcache. when i create a scene(whiteroom) where standing an object on a ground plane, then there appears these white blotches at the contact areas. if i render the scene with BF+BF all looks fine. the thing is, i want to render a hughe animation and BF+BF is not so fast as BF+LC.
    When i put a vray material on the ground plane, all works fine too.
    Had anybody the same problem in the past and a solution to solve that problem?
    white background
    invisible domelight with hdri
    Max2019 + vray 3.60.04
    thanks in advance
    Can you try with higher Retrace value for the LC ? Probably 8 will be enough to fix this.
    Tashko Zashev | chaos.com
      Hi, it is not the retrace option. I have just tried something again and if I set "scale" to world and the sample size is very low, then the bright spots disappear. Nevertheless, many thanks for the feedback.
