Vray LUT
  • Vray LUT
    Hello guys,
    I´ve been rendering my image for the last couple hours whilst rendering I played around with the correction controls on vray frame buffer,
    As i clicked on Lut active it changed my complete rgb output to a different gamma value.
    Now how to get my original back since even if I press inactive it doesn´t change.
    I usually work with gamma 2,2 i think.
    Please help me
    at the bottom of the VFB there is a button that says LUT, make sure that is switched off. To the left of it, hold your mouse down on that button so the flyout appears, select the button that looks like a curve
    Kind Regards,
    Morne
      Unfortunatly i checked that. It seemed converted completely
        If worse comes to worse, you can always reset the V-Ray renderer (i.e. assign the Scanline renderer as the current renderer and then V-Ray).
