Hi all.
We've recently updated from 3.4 to 3.6.
I need to render an animation for a client ASAP but can't. I have no idea what's going on.... Can anyone help?
I was expecting/expected to get the ball rolling on this render over the weekend.
So, I either need to an answer to fix my issue using my method below OR an alternative method while the process below that I've used for years is figured out.
The scene is rendering statics absolutely fine.
If we have to go back to 3.4 we will but we have got a few jobs in the works using 3.6. Will they work with 3.4? This is the first animation we've put onto render with 3.6.
I don't know if there's a bug in 3.6 or the process has changed since 3.4 but here are the steps we have always taken..... They have always given us perfect results.
1: RENDER LIGHT CACHE
+ Set to single frame
+ Tick 'Don't render final image'
+ In GI ----- Set to Light Cache & Light Cache
+ Subdivs = 2500 (varies per job)
+ Tick 'Use camera path'
+ Scale = World
+ Sample size = 0.15m
+ Mode = Fly-through
+ Untick Autosave
I first thought something was odd when rendering the light cache because what I'd usually get is something like this: This is from the chaos site and happens when use camera path is ticked.
This is what I get.... As you can see I'm not getting the usual use camera path action.
This is showing the last frame of the animation.... even though I have the timeline at frame 0
I saved the light cache file and it was just over 1gb.
I tried the above a few times and I got the same result.
I went ahead and went onto the next step anyway.
2: RENDERING IRRADIANCE MAP
+ Set shot 1's frame range
+ Set increment to 25
+ Didn't want to see render tests so left 'Don't render final image' ticked (as I'd done manual tests)
+ In GI == IM (Primary) & LC (Secondary)
+ Medium animation
Mode = Multiframe Incremental
+ Untick autosave
+ In the light cache section I set it to from file and load the LC
Press render in the render setup window
Computer says no.
It seems to start then just hangs.
Can anyone help?
Thanks,
Sean
+ Scale = World
+ Untick Autosave
+ Medium animation
+ Untick autosave
Computer says no.
Can anyone help?
Thanks,
Sean
