Lens Effect
  • Lens Effect
    I try the lens effect once in a while, but that is just because it's a 50-50 chance it'll work. Here are my current errors.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Are you trying to use a custom map of some sort?
    Chris Jackson
    Shiftmedia
    www.shiftmedia.sydney
      No, not at all. It was working the other day, but not today. Just stock default stuff.
      Bobby Parker
      phone: 2188206812
      • Ryzen 9 5900x CPU
      • ​Windows 11 Pro
        I think there was a bug like this that we fixed at some point so it should be better in the next update.
          Okay, thanks!
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
            I installed the latest V-Ray (Oct 5th) and I am still getting the lens error.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              can you delete everything (except the cam) from that scene and share it here so I can take a quick look?
              Kind Regards,
              Morne
                I can do it when the render is done. This last time I didn't get any errors, but there isn't any lens effect no matter what I do.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                  Windows update sometimes messes up the driver. Try reinstalling with the latest from your vendor (NVIDIA/AMD/Intel).
                  Best,
                  Blago.
                  V-Ray fan.
                  Looking busy around GPUs ...
                  RTX ON
                    Well, it works on some scenes 50/50. I have the latest NVIDIA driver.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                      Well, in case it is the driver, lens effects should always work with hardware acceleration turned off.
                      I always disable hw acceleration, because on high res images the whole system freezes for minutes while calculating lens effects.. Can't even see the mouse pointer moving...
