Sometimes effectsResult doesn't show the denoised image
  • Sometimes effectsResult doesn't show the denoised image
    Not sure if bug or not but sometimes after stopping a render involving a Vray Denoiser render element + Lens FX, the effectsResult pass doesn't show the denoised result unless I start fiddling with the Lens FX settings like turning on/off bloom or glare etc.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    Might be related to the way you cancel.
    Post effects will be updated when you press stop in the max render window.
    When you press cancel the render is canceled and no post effects will be calculated.
    Esc = Cancel and the "stop" button in the VFB is also cancel.
    German guy, sorry for my English.
      Fair assumption but this happens even if I stop it well into the rendering, like 5-6 minutes in. And in that time I'm seeing vray applying denoising on the image multiple times.
      Aleksandar Mitov
      96GB DDR5
        Can you make a video? And are you sure you are stopping the render and not cancelling it like Ihno said?
        Peter Matanov
        Chaos
          I will try to next time.
          Not sure. Why would this matter if the image was denoised before I stopped rendering? Shouldn't I be able to access the last denoised result no matter how I cancelled it?
          Aleksandar Mitov
          96GB DDR5
            Ok, it just happened again and I recorded it. See attached below. I canceled the rendering with the red "Stop" Button in VFB.
            Aleksandar Mitov
            96GB DDR5
              I wasn't able to reproduce the issue shown in the attached video. Would you send a scene to support@chaosgroup.com to check things out?
              Philip Shounev
              QA department
              Chaos
              philip.shounev@chaos.com
