VRayFastSSS2 is slightly different between CPU and GPU
  • VRayFastSSS2 is slightly different between CPU and GPU
    In V-RayNext, the textured SSS of VRayFastSSS2 is slightly different between CPU and GPU
    It is not seen in V-Ray 3.6.
    Test scene attached
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Well, the difference is really not that big to be honest. Just tweak the settings of the material a bit until you match it. You shouldn't be switching engines mid-project anyway. Once you start developing a scene, stick with the engine you began with to avoid these little inconsistencies. If you started with Adv/CPU, stick with Adv/CPU. Don't change it halfway into it.
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
      Sorry, your answer is not an answer.
      Chaos should not make minor tweaks to the user.
      Developers should be able to modify the program side.
      the V-Ray GPU and the CPU should be freely switched between each other.
      In addition, there is no problem with 3.6, and it is necessary to explain the reason why the problem comes up in V-Ray Next.
      oakcorp.net
      v-ray.jp
        No, they shouldn't. They are two separate engines. Minor or major differences are possible both between the engines and their major versions.
        Peter Matanov
        Chaos
          I understand that the V-Ray GPU is a different engine.
          However, as long as you sell it in the same V-Ray package, it is the developer 's efforts to make sure that there is no difference as much as possible.
          I made a new confirmation scene. It might be a trivial difference. But for artists it is a big difference.
          I confirmed, but neither Tex nor GI nor reflections are involved. There is a difference in SSS calculation of purely FastSSS2.
          Probably it is V-Ray GPU specification. I will say nothing more.
          gpucpu_sss2dif.zip
          oakcorp.net
          v-ray.jp
            Vray Next GPU gives different results compared to CPU in normal mapping, displacement, SSS and many other things
            They are not supposed to be 100% matching. The GPU architecture in Vray has been written from scratch to meet GPU rendering specs and Chaos Group did an amazing job in this.
            So you cannot switch from GPU to CPU in the middle of your project. Before you start you should decide whether you will use Vray GPU or Vray CPU
            There is no point of trying to match the results between CPU and GPU
            I think it might not be possible in many cases because GPU rendering has its own characteristics and limitations.
            Just think of them as different engines
            Muhammed Hamed
            V-Ray GPU product specialist
            chaos.com
              If you are comparing this to Cycles for example, expecting the GPU and CPU results to match, Cycles on CPU is just running the GPU code on CPU like what Vray does with Hybird rendering.
              So if you render your scene using the C++/CPU even if you don't have a GPU in your system, the result will 100% match rendering on your GPUs
              But like I said above, Vray CPU is something different.
              Muhammed Hamed
              chaos.com
                im fine with slightly difference. but if its to extreme i would become suspicious.
                for example if we dont see a differenve from one shot to an other im fine with that. so im fine with the example above.
                but if in one shot we see the char with brown hair (GPU) and in the other with black hair (CPU) something isnt in line.
                https://linktr.ee/cg_oglu
                Ryzen 5950, Geforce 3060, 128GB ram
                  oglu Yup
                  The extreme differences might be bugs or things that are not supported on GPU
                  Usually you will be able to tell if something is wrong/suspicious and report it to devs.
                  Muhammed Hamed
                  chaos.com
