Vray Next Vray Clipper and vray toon don't work together.
  • Vray Next Vray Clipper and vray toon don't work together.
    Hi all and Vlado,
    I am trying to get some complicated architectural organic crossections using vray clipper and vray toon. But toon doesn't work with the clipper, please have a look at the images. Is there anything i am missing ? My scenes have 20K objects and i want to do about 70 cuts. I would like to avoid using 70 group slice modifiers. IS there anything else i can do?
    164 core mini rendering farm - RTX 3090
    All with 128GB ram
    Windows 11
    3ds Max 2024 - vray - phoenix - forest pack
    Hello,
    Unfortunately Clipper and Toon don't work together - it's a known issue but we still haven't fixed it.
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Thank you Yavor, Is that something we could see soon or is it down ....down the line ?
      All with 128GB ram
      Windows 11
        If it's all one material you can use a material override with an edgestex in the diffuse? Or doesn't this work either? Or are you aiming for cell shaded graphics?
        A.
        www.digitaltwins.be
          Thank you Vizioen ... I use a simple white override material. But i like outlines like vray toon ... and the edge texture doesn't look how i want. I think if found a workaround i used the old 3ds max standard cameras with orthographic settings then i put the vray clipper and then i use the clipping planes of the camera aligned a couple of mm before the vray clipper. all the vray toon lines disappeared.
          All with 128GB ram
          Windows 11
            Great good to know.
            A.
            www.digitaltwins.be
              I haven't come up with a nice solution so far
              Yavor Rubenov
