remove ies file from VRayIES
  • remove ies file from VRayIES
    So by happy accident I realize that my lights look better without the ies file - because of a location path issue - so now I want to remove them but I can't right click on the slot and remove the .ies profile. Any suggestions? I'm on Vray 3.60.04
    Brendan Coyle | www.brendancoyle.com
    I found the same thing. You can just replace them. To automate this I use objectreplacer from the soulburn scripts. Would be more handy if you could just clear them ofcourse.
    edit: Found another trick. Remove them from your asset tracker by stripping the path and then remove missing assets. Results in an empty slot in your IES. (carefull if you have other missing assets you still need)
    A.
    www.digitaltwins.be
      Oh nice! I had tried removing the path but didn't realize I could also remove the missing assets. I need to save and reload the file to finally get the correct lighting response. Thanks
