VRayVolumeGrid Lacks Motion Blur
  • VRayVolumeGrid Lacks Motion Blur
    I am rendering a FumeFX sim cached as VDB with the VRayVolumeGrid, and am getting very pretty results, except for one thing: motion blur appears to be nonexistent. No matter how I twist the settings I can't get it to show any effect, even with huge multipliers. I am caching velocity out of FumeFX so the information is definitely there.
    Also, I can't seem to get any displacement using Volume Geometry mode, which is needed since I need deep output. I am working around this currently by rendering the displaced version in Volume mode and a deep pass with Volume Geometry, but this may cause trouble down the line.
    Is this fixed in later versions? I am using using 3.60.04.
    Hey,
    You can get a latest stable build from https://nightlies.chaosgroup.com (use the account for chaosgroup.com) where those things should be working.
    Different applications use different channels and names for them. When loading f3d/vdb files, VRayVolumeGrid tries to automatically make the conversion to the supported channels. If a channel is not mapped by default, a channel can be manually set in the Input rollout on the Modify panel by clicking the Browse [...] button under Preview & Render Cache Path and choosing 3rd Party Channel Mappings from the pop-up menu. From there you can choose the appropriate velocity channel.
    If you can't see the builds, drop an email to support@chaosgroup.com with a link to this thread.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hi Georgi, rendering with the nightly fixed the motion blur for me. I have noticed that Z/Y seems to come in flipped by default with FumeFX 5 caches, though the Fume 4 caches seem correct.
      I have however noticed something else: when rendering deep images with the VolumeGrid object in Volume Geometry mode, the samples all have infinite color values, and solid alpha, so the renders are essentially unusable within a larger workflow. The beauty image looks fine, just the deep output is messed up.
      Edit: Rendering using the FumeFX Fusionworks renderer with the VRay Deep Data option also produces the same infinite color and solid alpha values in the deep render.
        Hello,
        Can you send me a scene where this happens?
        Thank you,
        Georgi Zhekov
        Chaos
          In reproducing the issue in a blank scene it seems the problem may be on our end. I'll investigate further.
