Vray Next GPU DR use local host require Render Node license...
  • Vray Next GPU DR use local host require Render Node license...
    Too bad I have one workstation and one renderNode only...
    You have 1 Workstation license package - https://www.chaosgroup.com/support/f...in-the-license . If you want to work with 3dsMax on 1 machine and send the rendering to another - you can un-check "Use local host" from "V-Ray interactive rederer DR settings"
    Click image for larger version  Name:	GPU_DR.png Views:	1 Size:	22.8 KB ID:	1018401
    Ivan Slavchev
    SysOps
    Chaos Group
      No, I want to use all my gpus, including the workstation ones...
        Just like with VRay cpu...
          You need 1 render node license per each machine, so in that case you should obtain 1 more license for the second computer.
          Ivan Slavchev
          SysOps
          Chaos Group
