Distributed wont work on Update 1
  • Distributed wont work on Update 1
    ???? any similar problems????
    Archviz Designer. 2x 2990wx + 4x 1950x + 3x 1800x / Nvidia RTX GPU.
    3dsmax / maya / vray / corona / redshift / unreal / fstorm / arnold
    Hello,
    It is working here in a simple test.
    - What is your Max version
    - Does it happen on any scene
    - How many DR machines are you using
    - V-Ray or V-Ray GPU
    - Do you see any errors/warnings in the log
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Hi. Yavor
      3ds2018 / yes any scene / 1workstation + 5 nodes / both / yes, talking about cant reach at sockt. /
      I disable windows firewall and works. But never was necessary disable firewall, so before i format all machines can you tell wich components i need to give firewall permission. because keep firewall disabled is kind unconfortable. ty, and congrats for this amazing work"!
      PS.; the problem is output, i need to disable only on master machine. the otthers is not necessary disable firewall. i try to put vrayspawner cpu mode on list and not work. Must have a diferente component on this new update, who was blocking the data send.
        V-Ray DR uses port 20204 and V-Ray GPU uses port 20206 - it should work if you add exceptions only for those ports.
        Yavor Rubenov
          Ty . its working now. Cool
