Vray Next (update 1) crashing with Forest Pro
  • Vray Next (update 1) crashing with Forest Pro
    Using Vray IPR or interactive rendering, max 2019 is crashing when manually moving or rotating Forest Pro items.
    What is your Forest Pro version? Can you give me reproduce steps and a scene?
    Peter Matanov
    Chaos
      Hm it seems you'll have to wait for a new FP version that officially works with Update 1.
      Peter Matanov
      Chaos
        Shitloads of crashes with FP on various occassions. As Slozer said this will most likely be on FP side
        Martin
        http://www.pixelbox.cz
          Man...don't things get tested before they are released?
          Vincent Jaramillo
          Smithgroup
          301 Battery Street
          San Francisco, Ca 94111
            ipr does not support fp very well. Don't expect to be painting trees in realtime. Additionally they informed me that 4.0.25 is the version that's currently supported but I would not expect wonders from the ipr side. Gotta be reasonable.
            Dmitry Vinnik
            Silhouette Images Inc.
            ShowReel:
              Actually FP works well with IPR. And I will not get tired of saying the same thing on every release - 3rd party plugins should state that they explicitly have support for our new version. Using versions that are not compatible with each other is at your own risk.
              Peter Matanov
              Chaos
                Well, I reported an issue to them about painting / removing trees by paint brush while ipr was running which caused max unhandled exception and crash but they said it was one of those things that was not very well supported.
                Dmitry Vinnik
                ShowReel:
                  Funny...When Chaosgroup TV demos forest pack and IPR, it works fast and seamlessly. I know they are using GPU mode but it works. Now your telling me it doesn't?
                  Vincent Jaramillo
                  Smithgroup
                  301 Battery Street
                    I have no problem with Forest Pack and latest VRay. IPR works fantastic with Forest in CPU mode. I had much more trouble in VRay 3.6 with constant crashing in IPR when FP was in scene. But in Vray 4 and 4.1 I have no problem so far.
                    AMD TR 7980X, 256GB DDR5, GeForce RTX 4090 24GB, Win 10 Pro
                    2D | 3D | web | video
                    jiri.matys@gmail.com
                    https://gumroad.com/jirimatys
                    https://www.artstation.com/jiri_matys
                    https://www.youtube.com/channel/UCAv...Rq9X_wxwPX-0tg
                    https://www.instagram.com/jiri.matys_cgi/
                    https://www.behance.net/Jiri_Matys
                    https://cz.linkedin.com/in/jiří-matys-195a41a0
                      CPU IPR is having problems in Update 1 and the last version of FP (which DOES NOT support Update 1 officially). GPU IPR is working in a different way and it should not be affected by this. Can you show me a ChaosGroup TV demo with FP and Update 1??
                      Peter Matanov
                      Chaos
