Viewport IPR mode and Forest Pack
  • Viewport IPR mode and Forest Pack
    When I turn on the IPR mode in the viewport...New Viewport IPR. It renders the Forest Pack elements as point cloud vs the actual geometry. As I rotate in the viewport, I can see the rendered geometry but the point cloud display follows it and stays on top.
    Vincent Jaramillo
    Smithgroup
    301 Battery Street
    San Francisco, Ca 94111
    Then lower the point-cloud density in the viewport?
    Peter Matanov
    Chaos
      Hello,
      The easiest fix for this is to enable proxy display mode instead of points-cloud. You can easily switch all the FP objects in a scene using Forest Lister.
      Hope that helps.
      Paul Roberts
      Training Manager - iToo Software
        Thanks...I'll try it out.
        Vincent Jaramillo
        Smithgroup
        301 Battery Street
