Vray Next GPU suddenly slow
  • Vray Next GPU suddenly slow
    Hello Everyone.
    So I had set up a turntable animation for a product showcase for a client of mine. I have decided on this occasion I would use Vray Next Gpu to speed things up a bit. My test renders were between 45-90 seconds per frame. I use speed fan and noticed my GPU temps were all of sudden down below 30 degrees. They had been up to 70C on first 30 frames of animation. Not significant changes in scene from frame to frame. Building light cache is taking forever and the renders have gone up 12-13min.
    Any ideas on what could be issue of tips on optimising?
    Michael
    With the latest vray gpu update 1, after reinstalling it 3 times to make it barely work, it renders VERY very very slow.
    It was giving me errors and kept compiling gpu kernel at least 4 times before i closed max. Screenshot added
      i did a clean install of latest nvidia driver, so far it seems like vray is working ok
        Originally posted by BBHead View Post
        Hello Everyone.
        Michael
        Seems like it's falling back to CPU. Can you post your system specs? Can you send me the scene? Have you checked the log for errors?
        Peter Matanov
        Chaos
          Sorry for the slow reply. So I figured out what issue was. I had added a vray light material to one object in the scene after intial test renders. After I removed this the render times went back to the 45-90 seconds. Is Vray light material a known issue?
          Michael
            No, it should work fine. Can you send me the scene?
            Peter Matanov
            Chaos
