3dsmax 2018 crash after install vray 3.60.04
  • 3dsmax 2018 crash after install vray 3.60.04
    After installing as network license, and try to switch from scanline to vray renderer, Max gets crash and shut down itself. I have tried this with 2 Xeon. One is windows 8.1 and the other is windows 10. Both get the same Max shutdown. Do you have any suggestion?
    Hello,
    When you get the crash Max should create a crash dump file called 3dsmax_minidump.dmp in your temp folder (%temp% in the windows explorer address bar). Could you send one dump to our support so that we can check what is the problem
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      I attached it now, try to attach and send it on support page but can't see any available attachment
        Hello,
        Thanks for the crash dump.
        There is a file called vray2018.dlr in your Max plugins folder (C:\Program Files\Autodesk\3ds Max 2018\Plugins) - it is not part of our files and causes the crashes.
        Yavor
        Yavor Rubenov
