Backburner not saving VFB lens effects
  • Backburner not saving VFB lens effects
    Hi!
    We've been rendering animations through the network using Backburner and V-Ray 3.6 for 3ds Max 2016. While some machines render perfectly, it's pretty common to get frames where the lens effects are not applied. What can be causing this?
    Cheers
    V-Ray Evangelist, Trainer and Freelancer
    www.behance.net/rickeloy
    Disable hardware acceleration?
    A.
    www.digitaltwins.be
      Are the Backburner servers (slaves) running as a service or are they started manually on the nodes?
      Ivan Slavchev
      SysOps
      Chaos Group
        All running as services (sorry for the late reply)
          Try starting backburner slaves manually, so VFB will appear when rendering. Lens effects are applied via the frame buffer, so if the frame buffer doesn't launch they won't be applied.
          Ivan Slavchev
          SysOps
          Chaos Group
