Can't find Origin of Warning
  • Can't find Origin of Warning
    Using the Next 1.1 IPR Viewport rendering mode, I am getting this error on repeat, and can't find it's origin. Any ideas?
    "warning: Multipass mode is not supported anymore, switching to single pass mode."
    Thanks in advance,
    -Joel
    -Joel E
    https://www.biglittlepictures.com
    Hello,
    This message is from the denoiser - probably you have some old scene from 3.6 where the denoiser had a parameter "type". You should be seeing this only when manually running the denoiser ?
    Yavor
    Yavor Rubenov
    V-Ray for 3ds Max developer
      Cool. Removing the Old Denoiser element and re-adding a new one stopped the repeated warning.
      Thank You Sir!
      -Joel E
