Recently discovered this bug.
Vray will crash when using the Physical camera with a modifier applied and non-zero perspective correction settings (vertical/horizontal shift/tilt or auto-correction checked)
To reproduce:
1. create new scene
2. add a Physical Camera
3. add an empty modifier like Attribute Holder or XForm to the Camera
4. in Physical settings under Perspective control change Vertical Lens Shift to any number other than 0.0
5. hit render
At this point the render process window will come up and hang on "V-Ray starting rendering..." but it will hang indefinitely without rendering.
Can someone check on their end if this also happening.
Edit: That should be vray 3.60.03 not 3.36.03 like it says in the title
To reproduce:
1. create new scene
5. hit render
