Stopping a rendering
  • #16
    I'll look deeper into this. I just brought my slave, which is a BOXX RenderPro, into my office and I can hear it spinning 30 minutes after each render. No, it's not half of what my main machine is.
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    • #17
      Can you send the logs from the salve and main machine to support@chaosgroup.com ? It might be good to connect remotely and perform a few tests.
      Tashko Zashev | chaos.com
      • #18
        Another project that renders black and I can't stop my light cache. I'll send this one over right now.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
        • #19
          Upload failed so I am uploading it again. GPU Hybrid renders fine.
          Bobby Parker
          phone: 2188206812
          • Ryzen 9 5900x CPU
          • ​Windows 11 Pro
          • #20
            I see a raytrace error in the V-Ray messages. How do I find it? There used to be a script, but it stopped working a long time ago.
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
            • #21
              Have you tried the right click - V-Ray scene converter ?
              • #22
                Yes, I do that with every project. It never has found raytrace materials.
                Bobby Parker
                phone: 2188206812
                • Ryzen 9 5900x CPU
                • ​Windows 11 Pro
                • #23
                  Can you try to find the Raytrace maps in the slate editor ? You can get the map number from the Log - Warnings.
                  The converter script works in most situations, but if you have raytrace maps attached to different material slots than the Reflect/refract it will not touch them. Also It won't convert raytrace map when is part of a V-Ray Mtl.
                  • #24
                    Yeah, I have been looking for it. Why does it totally cripple the render? I am using GPU, so I am fine for now.
                    Bobby Parker
                    phone: 2188206812
                    • Ryzen 9 5900x CPU
                    • ​Windows 11 Pro
                    • #25
                      I assume you have `show incompatible` turned on or it may not be visible in the material editor ? Maybe a raytrace shadow on a standard light or does Vray convert those, I can`t remember ?
                      • #26
                        Raytrace map is unsupported and as a such can lead to rendering problems. If the scene renders fine without it, that's great, but if the issue continue then we will need to inspect the scene.
                        • #27
                          It doesn't render in the CPU at all. GPU it is rendering great. I haven't tried my exterior scenes in GPU, but I tried here and it worked, so that is good. I sent you the scene yesterday.
                          Bobby Parker
                          phone: 2188206812
                          • Ryzen 9 5900x CPU
                          • ​Windows 11 Pro
                          • #28
                            "show incompatible" I can't find this. (found it!)
                            Bobby Parker
                            phone: 2188206812
                            • Ryzen 9 5900x CPU
                            • ​Windows 11 Pro
                            • #29
                              Searching from the top pulldown, in the material browser, allowed me to find it. I searched Raytrace and it listed it.
                              Bobby Parker
                              phone: 2188206812
                              • Ryzen 9 5900x CPU
                              • ​Windows 11 Pro
                              • #30
                                Does it work fine now ? If not you can share the scene to try it here.
