VFB Lens effects - streak blur hit and miss
  • VFB Lens effects - streak blur hit and miss
    Hi Guys
    The new lens effects in Next 1.1 is pretty awesome.
    Just the streak blur seem to work only every 2nd time.
    Reproduce:
    Open Max, (no scene)
    Load an exr into the VFB
    Switch mode to Image and Render element
    Switch layer element from dropdown to Glare
    Adjust streak blur by typing values.
    I wait for the adjustment to take affect in the VFB before I adjust again, but seems intermittantly, only every 2nd adjustment does anything even if you jump by 0.2 at a time
    For example from the default 0.2, go to 1. 1st time it may work. Then go back to 0.4, nothing happens. Go to 0.1, fine, back up to 0.4 fine, 0.6, nothing again, etc.
    Kind Regards,
    Morne
    Thank you for reporting this. I have reproduced it here and reported it as a bug into our bug-tracker.
    Will notify you, when there is any progress.
    Best Regards,
    Martin Minev
    Chaos Group Support
    Martin Minev | chaos.com
