The VFB frame output doesn't work with number sequences properly
  • The VFB frame output doesn't work with number sequences properly
    clientname- pinball ident anim__shooter_cam_a_.0000.0000
    When I click on a file sequence with numbers in Max, it will understand the appended numbers and act accordingly - ie, append the correct frame numbers.
    With VRAY, however, it's just added on an entire new set of appended frame numbers.
    I can't wait to see if that fucks up loading in frame sequences into After Effects or Premiere!
    http://www.jd3d.co.uk - Vray Mentor
    I have made some tests here and the frame output number sequence using V-Ray raw image and Separate render channels output works as expected. Would it be possible to provide us steps to reproduce the following issue.
    If you can send us an example scene to support@chaosgroup.com, will also help us to troubleshoot.
    Best Regards,
    Martin Minev
    Chaos Group Support
    Martin Minev | chaos.com
