ppt animation problem
  • ppt animation problem
    hey...
    been playing around with the ppt-rendering in the latest beta for a few hours now and its awsome...
    but when I tried to render an animation using the ppt technique it turned out totally black.
    everything looked great in the framebuffer window during rendering, and the finished animation is 70 mb big (so something was saved), but when I play it in the mediaplayer or somewhere else every frame is just black...
    is it impossible to render anims with ppt at the moment, or have I missed something here?
    from where and how did you save the animation ? did you save it from the Vray frame Buffer ?
    Natty
    http://www.rendertime.co.uk
      damn youre fast...
      ah, maybe thats the problem... i saved the anim from the common rendersettings rollout, and used the Vray frame buffer while rendering... so it probably saved the black standard max framebuffer to the animation and did nothing with the Vray frame buffer?
      is it possible to save an animation directly from the Vray frame buffer?
      thanks!
        well to be honest i wouldnt for now as there were some issue's .. save it from max's FB .. then adjust it in Premiere if you have to ..
        Natty
          ok... ill do that...
          thanks again for the fast reply!
