Exit Color
  • Exit Color
    I just notice that in the new Vray Next the Exit Color option isn't present. Where was it moved as I can't find it? In the older versions, it used to be located next to the Fog option. The Vray Docs still states it as an option. Thanks in advance. Cheers
    https://docs.chaosgroup.com/display/VRAY4MAX/VRayMtl
    Hello!
    In V-Ray Next refraction exit color is no longer visible in the UI. We will update our documentation. Thanks!
    Tanya Todorova
    QA
      Thank you for the reply - if it’s no longer visible in the UI doesn’t this mean the option as been removed from Vray all together? Or is it found elsewhere? Is there a work around?
      cheers!
        Hello! I meant that Exit color was removed in V-Ray Next. You might find helpful reading this thread :https://forums.chaosgroup.com/forum/...732-exit-color
        Tanya Todorova
        QA
          gone? just saw a video about Clarisse 4.0 were one can use an HDR to map it into the refl/refr exit color, really nice because one don't need extra high ray depths
