Vray Next - artifacts on reflections and depth of field
  • Vray Next - artifacts on reflections and depth of field
    I've just updated my Vray to Next. Rendering an scene, that I was working on, with Vray 3.6, I've noticed those strange artifacts on the leaves of the plant in front of a mirror. In the new scene (Next) I just changed the camera (I used the new Vray cam) and switch off a light from a window coming from the right (I used the new adaptative dome). Everything is the same as the 3.6 scene. The postpro has changed, so you may notice some diferences.
    You can see the image rendered with 3.6 with no arifacts. The image rendered with Vray Next has those weird things around the leaves...
    If anyone can help me with this issue I would appreciate it.
    Thanks
    jerocg.com
    I've just noticed is the VraySpecular render element who is causing this artifacts. It has been denoised, so I think thats the problem... I'll try without denoising.
    jerocg.com
      Hello,
      Could you send us the scene to support@chaosgroup.com, so we check what is causing it. Please also mention this thread.
      Martin Minev | chaos.com
