Noisy Matte Shadows
  • Noisy Matte Shadows
    Hello,
    I am having a bit of trouble with matte shadows, I cant get them to clean up to a satisfactory level. Is there something i am doing wrong on my end?
    I have attached 2 images that show the problem - both are using the same settings but the matte version has much more noise in the shadows.
    I have tried using both the material wrapper and the VRay object properties and get the same results.
    The scene is a simple dome light with a plane light to cast a shadow and the teapot has a chrome shader applied and the floor is a 128 grey default VRay shader.
    This should be fixed in the latest update of V-Ray Next. If you are not using the latest version, could you update and try again.
    Martin Minev | chaos.com
      Originally posted by Martin.Minev View Post
      Hi Martin,
      I am using V-Ray Next for 3ds Max, update 1.1 that was released on 18th of December 2018.
      This is the latest version i can see on the download portal.
        According my test, using the latest V-Ray Next 1.2 from 27th of March and replicating your scenario, there is almost not any noticeable difference.
        Could you send us your example scene to support@chaosgroup.com for investigation. Please mention this thread.
          Strange!
          I have attached attached a few images using vray next 1.2 - i am getting the same result as before.
          If it is working on your end it must be user error. I am using 3d max 2016 if that is of any relevance.
          Will send a scene through to support.
          Thanks for your help!
