So, I'm trying to animate a material with a noise component - the noise has animated offsets and phase - and when I render out an animation with those curves set, I do not see it reflected in the animation as I would expect. changing the first and last keyframes results in the material changing as expected, but only for the first frame rendered. When I render individual frames along the timeline, each snapshot is animating as I'd expect as well. I'm using 3dsmax 2018 with VRay Next 1.1.
Here's a scene that demonstrates the issue. https://drive.google.com/file/d/1R7Z...ew?usp=sharing
What can I do to fix this?
