Forest Pack Color Tint broken in Vray GPU
  • Forest Pack Color Tint broken in Vray GPU
    Has this been fixed? Somebody on the itoo forums said this was fixed a while back in a vray update, however I still am unable to get color tint in Forest Pack to show up with Vray GPU.
    Do you use the Color tint from the Forest node (modifier panel) ? It should work if you activate it from the Forest Map > Override tint. Can you try it ?
    Tashko Zashev | chaos.com
      It works from the material controls but it does seem that the modifier panel is ineffective when in GPU.
        I see this is already logged in our system. So you can use the map parameters as a temporary workaround until we add support for the tint parameters from the node in GPU.
          Hello,
          A little UP here, it has been 2 years since this last message. And nothing has changed.
          Considering the new very cool feature in the last Forest Pack 7, would you please really consider dealing with this issue ?
          Regards
