Very high unloading times after rendering
  • Very high unloading times after rendering
    Hey,
    I have a scene here with some VrayDisplacement and some ForestPack objects which takes around 10 minutes to unload after finishing or canceling a render. The rendertime is actually quicker then unloading. While unloading, you can see the 3dsMax task slowly lowering RAM usage. Is there anything that can be done to speed things up?
    V-Ray Next 4.10.02, Max 2017, Forestpack 6.20
    Regards
    Oliver
    Yes, there is. Most common reason for this is proxy files created with earlier V-Ray version - those are not optimized and if there are thousand of proxies in the scene such slowdowns are monitored at the end of the rendering.
    Please stay tuned I'll let you know how to determine whether the slowdown is indeed caused by old V-Ray Proxy files and what to do in order to speed up RAM releasing after render ends.
      In addition to what Svetlozar pointed out, it would be great if you can get us a scene with this issue so that we can profile the exact reason for the slowdown.
        OK, I wrote article about this since it happens from time to time. Please visit the link bellow, check if Optimize for Rendering is enabled for the proxy files used in the scene and let us know if slowdown disappears when it is enabled.
        https://sites.google.com/chaosgroup....-v-ray-proxies
        Looking forward to hearing from you.
          Quick note to confirm we were having this exact issue (long time unloading after rendering). went through converting each proxie back into a polymesh, then back into a new proxy with "optimise for rendering" checked and no issue. Nice to see the proxies vray next created were x4 - x5 times smaller too!
            Very nice to hear.
            However, You should know that in that mode partial proxy loading is *not* possible.
            So, provided your proxies are somewhat compact geometries, like a bottle, a tree in full view, a car tyre, or other such type of nodes, even if there are many in a scene, all is fine, and you can benefit from the speedups.
            If your proxy is however very extensive, like a whole building with the furniture, a terrain with all the scattered geometry, and so on, this option would prevent piecewise loading, and make you incur in serious RAM penalties.
            Lele
            emanuele.lecchi@chaos.com
            Disclaimer:
              I have no proxies in my scene at all. I will prepare it and send it to Vlado.
              By the way, we found out today that proxies now support modifiers like bend, VrayDisplacementMod and so on. Couldn't find anything in the docs, when was this added?
                The same applies to rendertime (ie. dynamic memory pool) displacement, in fact, especially if it's tasked with a lot of triangles (ie. screen-space, low edge size/big image resolution).
                If you have the ram, set it to 3d, static, and the issue of ram unloading should go away.
                You'll likely also gain some decent speed in rendering, albeit with a longer startup phase (as displacement gets calculated and then put into the acceleration structures as explicit triangles).
                Lele
                Disclaimer:
                  Not sure, it's been in the builds for a while, but I can check the exact build if you need it? Keep in mind that adding any modifiers on the proxy will turn it into a regular mesh instead of being loaded on demand.
                  Best regard,
                    I didn't open the scene today, but I think it already is the way you described for the displacement. Anyway, a scene was sent to Vlado.
                    Best regard,
                    It would be nice if any info regarding this feature could be added to the documentation. I checked yesterday but could only find the outdated notes that this is not supported.
                      Thanks for the feedback, added it into ToDo list of our Docs Team!
                        While it gets into the Docs, know the logic is pretty simple: it's as if you chose the full mesh preview in viewport, and then added modifiers.
                        It's slightly better because it won't slow down the max session, but -as Vlado said- will negate the on-demand, piecewise loading of the proxy.
                        Conceptually, one should be done with all the operations on a mesh, and then proxy it (i know of exceptions, of course. still.).
                        Lele
                        Disclaimer:
                          Just wondering, would it be possible to display a warning if a proxy should be reexported for performance optimization ?
                          Gil Guminski
                          cynaptek.com
                            I doubt it, purely because the "performance optimisation" is so only in this specific case, it would be detrimental to rendertimes and memory management when the scene was with different kinds of proxies (f.e. whole terrains, whole forests), and extensive enough to not fit in RAM.
                            You can however query the proxy for its properties with the commandline found in the bin folder of your v-ray install, like so:
                            Code:
                            ply2vrmesh -info myProxy.vrmesh
                            If the "Number of voxels" parameter reads other than 1, it'll be slower to load and unload than if it did read as 1.
                            This, let me stress it, *only* if the proxy (with all the rest of the scene data) indeed fits in RAM.
                            Lele
                            Disclaimer:
                            • #15
                              We are still suffering from extreme unloading times. Sometimes it takes 15-20 minutes, depending on the RAM the scene used. The more RAM, the slower the unloading process. No proxies in the scene, ForestPack instances the objects from meshes in the scene. Converting to proxies doesn't make any difference in terms of speed or RAM usage, it is exactly the same.
