Vray Proxy & Fence Selection Region
  • Vray Proxy & Fence Selection Region
    When working with Vray Proxies, the "Fence Selection Region" selection method (as opposed to the standard rectangular method) does not work, ends up selecting as if you had done a rectangle encompassing the area you tried to select. This does not happen with standard max objects.
    Also when doing area selections on vray proxies, the Window/Crossing setting is ignored and the proxies are always selected as if crossing was enabled.
      Thanks for the pointer; I've noted this down for fixing, if possible.
