IPR Freezing
  • IPR Freezing
    Hi everyone! I have a problem with IPR. It was working fine before yesterday and suddenly this happened.
    With the "fit resolution" option activated if I expand the window interactively to increase or decrease the window the program gets stuck (I cant do anything).
    If I press Ctrl+Alt+delete to see if the program is blocked, IPR resumes the calculation.
    But if I try to enlarge it again, the image and the program freezes like before. This does not happen if I use Vray GPU as Renderer.
    Does someone of you have or had the same issue?
    Thanks for helping out.
    Which V-Ray version is this ? Is it scene specific ? Can you try to reset Max (renaming the ENU folder) and reinstall V-Ray ?
    Tashko Zashev | chaos.com
      Hi, It worked with renaming the ENU folder! Thanks a lot!!
        Good to know that, thanks for the update.
