Still don't seem to be able to save an EXR with render elements that will open as in Photoshop from the VBF.
If I save from the frame buffer dialogue "V-ray raw image file" save as EXR, then photoshop will bring in all the render element layers. Save out an EXR from the VBF window as openEXR, photoshop only brings in the diffuse and alpha.
A 1080p frame saved from the Vimg dialogue is 42mb, saved from the VBF with "automatic" set for layers in the render element section of the OpenEXR save dialogue, is only 14mb. (that is data missing)
I tried manually selecting render elements and turning them ON in the save set-up, but closing the dialogue and checking set-up again, they are still flagged OFF. Could this be to do with Vray render element tab needing the elements to be turned OFF?
I'm using the EXR-IO (2.0) plugin for PS 20
