Update 2 "Save to a Single File" bug
  • Update 2 "Save to a Single File" bug
    When I use the region render on a small portion of an already completed render, if you try to save the completed exr using the "Save to Single File" option; only the region render portion gets saved out regardless of what is shown in the frame buffer.
    This bug does not occur if you save the render elements separately. Please let me know if there is a work around.
    Thanks for the report. I'll make a note about it for our developers to look into. For now, use the separate render channels saving method, until this is resolved.
      I have done the very same thing and it works without issue (see attached nuke image).
      The exr's bounds are set to the region, but the image size is preserved.
      Do you have an exr to share?
      Lele
      emanuele.lecchi@chaos.com
      Disclaimer:
        I uploaded to exr's here:
        https://gofile.io/?c=4mZDRa
        "Test1.exr" was rendered normally at the full resolution. As you can see from the file size and the resulting exr there are no issues.
        "Test2.exr" was after doing a small region render on a portion of the original render. As you can see from the smaller file size and the actual image, everything but the newly rendered area has been discarded.
        Attached are also previews of the result.
        Once again this only happens when using the "Save to a single file" option.
        Please let me know when there is a nightly/ hotfix for this.
        Thanks
          I'm using Max 2019.3, and this problem occurs on both CPU and GPU render engines.
            Duh me!
            I thought it saved just the crop, as in it changed image resolution.
            I can then confirm the behaviour: the image i show there was with the rest of the render around it, and saved with black.
            Sorry for the misunderstanding.
            Lele
            Disclaimer:
              One of the guys is looking into this.
                The issue has been fixed. Until the fix is implemented in the stable builds, you can add the VRayOptionsRE, set the 'exr data window' to 'whole image' and save your exrs with the 'V-Ray raw image file' option in the frame buffer settings. Using this method will save the whole image regardless of the region.
