Material Editor Freeze
  • Material Editor Freeze
    I have a single material that freezes MAX while it is in the material browser. It can be in the scene, just not in the editor. I found and removed the raytrace, which isn't the issue. What can cause this? I purchased the material and it has screwed up every scene I tried to use it in.
    https://documentcloud.adobe.com/link...7-809ddd5e7ad4
    Bobby Parker
    www.bobby-parker.com
    e-mail: info@bobby-parker.com
    phone: 2188206812
    My current hardware setup:
    • Ryzen 9 5900x CPU
    • 128gb Vengeance RGB Pro RAM
    • NVIDIA GeForce RTX 4090 X2
    • ​Windows 11 Pro
    Looking into it...
      For me the material swatch is simply slow to update but does not cause a full freeze of the application. According to VTune, most of the CPU time when updating the swatch is spent on calculating some procedural Noise textures (see attachment). However looking at the shading network for this material, doesn't it seems just a bit overcomplicated?
        Yes, it is a mess when looking at it that way. My machine freezes for several minutes and all I can do is try to remove it from the material editor before it freezes for several more minutes. I guess I'll abandon the material.
        Bobby Parker
        phone: 2188206812
        • Ryzen 9 5900x CPU
        • ​Windows 11 Pro
          Hi Bobby
          I'm interested on how this material looks like, can you share a link?
          Muhammed Hamed
          V-Ray GPU product specialist
          chaos.com
            https://www.turbosquid.com/FullPrevi...cfm/ID/1073911
            https://www.turbosquid.com/FullPrevi...cfm/ID/1074037
            Bobby Parker
            phone: 2188206812
            • Ryzen 9 5900x CPU
            • ​Windows 11 Pro
              I love a good procedural material but this seems to be overkill and or probably achievable in an easier way...
              cleaning this up would take some time though. Crazy node tree!
              Why is this in the docs section btw?
              Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
              www.AddYourLight.com
              Always looking to learn, become better and serve better.
                Maybe open a support ticket and ask for a refund, explain to them how this material crashes Max at all. Otherwise, RIP those 50 Euros
                I don't know why this is in the docs section, probably a mistake MANUEL_MOUSIOL
                Muhammed Hamed
                chaos.com
                  At least if the material looks ok you could try to render a couple of large textures (some 100 by 100 m). This way it doesn't completely go to waste.
                  pixel bender @ panoptikon
                    Exactly what I was thinking! Could turn out to be very useful. And you can strip out the useful parts and maybe use those to build a more streamlined version.
                    Out of interest does the slate mode make it any quicker to 'see' or is it the same in either mode?
                      But then if you render it to a
                      texture the procedural benefits of the shader would be gone..
