Can't stop IPR or close the IPR window
  • Can't stop IPR or close the IPR window
    After updating Vray to the latest version of Vray (4.20) I started getting occasional problems with IPR and to be more precise, not being able to stop it and close the IPR window. Clicking the red Stop button or the X button on the window doesn't do anything and I have to kill the Max process in Task Manager. This happens on 2 different PCs here. Unfortunately, I still haven't figured out the pattern of when it does this. It almost seems that it does this randomly. Anyone else noticed this after updating?
    Aleksandar Mitov
    www.renarvisuals.com
    office@renarvisuals.com
    AMD Ryzen 9 9950X 16-core
    96GB DDR5
    There seems to be some issue with this update that I'm currently investigating that causes seemingly random failures in various places. Looking into it now.
      Awesome, thanks!
      Aleksandar Mitov
      96GB DDR5
        Forgot to say that, but if you can get me a scene to vlado@chaosgroup.com which reproduces the problem (even if it's random), it will help a lot!
          Sorry for the delay. I've just sent you a couple of scenes to test. I hope these help! I can send more if it happens again.
          Aleksandar Mitov
          96GB DDR5
            Hello!
            I tried to reproduce the issue with your scenes (thank you for sending them!) but with no luck so far.
            If you could remember the exact actions you did during the IPR session it would help us a lot!
            If this happens again, please, describe them as far as you can remember.
            Margarita
            Margarita Stoeva | chaos.com
            Chaos QA (V-Ray for 3ds Max)
              Hi, Margarita.
              Ok, I'll try to remember the steps next time. Hopefully we can get to the bottom of this.
              Aleksandar Mitov
              96GB DDR5
                I'm pretty sure I finally reproduced it; I'm working on a fix and I will send you a build to test.
                  Sounds good! I'm eager to try it out.
                  Aleksandar Mitov
                  96GB DDR5
                    IPR has just locked up on me again without being able to stop it. Here's what I did before it happened:
                    1. I started IPR from the VFB window
                    2. I clicked the Refresh interactive rendering button almost immediately after (by mistake, I wanted to click on the red Stop button instead)
                    3. IPR locked up and I couldn't stop it or close the VFB anymore.
                    I've just sent these reproduction steps and the scene to Vlado. Let me know if you need more info. I'm ready to test the new fixed build if you have one ready.
                    Aleksandar Mitov
                    96GB DDR5
                      I have this from time to time, mostly when I'm too fast for IPR it seems.
                      I'll chime in when I can give more info and a scene, but interested in updates!
                      Add Your Light LogoCheck out my tutorials, assets, free samples and weekly newsletter:
                      www.AddYourLight.com
                      Always looking to learn, become better and serve better.
                        Indeed, i found the same kind of issues pressing IPR buttons too quickly.
                        In my case i was entering max into a zombie state, starting IPR, stopping it, and pressing the standard render icon.
                        Click, click, click to destruction. XD
                        I think it's fixed in recent builds though.
                        That, or i decrepified very rapidly, and am not fast enough anymore. :P
                        Lele
                        emanuele.lecchi@chaos.com
                        Disclaimer:
                          Lele, you are just too slow!
                          but actually I was talking about scene changes that make IPR hang. Sometimes 3ds max Crashes, Sometimes I just vray errors and have to restart 3ds max, Sometimes IPR hangs and I have forcefully close 3ds max.
                          ​​​​​​​it is happening when quickly putting a number of maps in a material for example.
                            I wanted to bring back this topic. I'm getting this issue as well, using the latest version of Vray Next, update 3.1 (4.30.01 build 00001).
                            Wasn't getting this issue with this project until recently, not sure exactly what caused it, I've been just adding 3d models that I've been purchasing as I go. One way to make it happen for sure (in my project at least) is to scrub in the timeline.
                            I have something like a lobby scene with random objects. Total polygons 24 million, using an RTX 2080 Ti with latest drivers.
                            The only way I can access the stop button or the close window X button is waiting until the render is complete done (when it says "done" on the info bellow, otherwise I have to reset Max and reopen my scene.
                            In my case I don't think is my computer being slow but something with the UI of the IPR, because my settings are pretty lowres and when it starts rendering it finishes really fast.
                            • #15
                              I know it is not a solution, but have you tried running this maxscript command :
                              Code:
                              vrayStopIPR()
                              It should at least allow you to stop the IPR without having to wait for the render to complete.
                              mekene
