Reflection/Firefly Issue
  • Reflection/Firefly Issue
    Hello,
    it has been some years since we last had fireflies in one of our renderings, but since a few weeks we occasionally get them.
    We tried to nail down the problem and it seems it´s due to our ReflectionMap. We use a simple plane with an VrayLightMtl assigned. The VrayLightMtl has an image in the lightcolor slot and an alpha map in the opacity slot.
    I´ve attached a simplified version of our setup with a checker map in the opacity slot.
    If we disable the opacity map everything renders as expected, but with an opacity map assigned we get fireflies.
    Any idea on how we can get rid of the fireflies and still use the opacity map?
    Thanks and br,
    Hello,
    I don't get fireflies with the attached scene. Also there is no map in the lightmtl color slot.
    Peter Matanov
    Chaos
      Thanks for your reply!
      That´s interesting, here is our Rendering:
      We use Vray Next update 1.1, but I will install update 2 and see if that helps.
        I’ve also had firefly problems lately. Updated to 4.2 and it got worse.
        Im going to send a scene to the support and see if they can find out what’s going on.
        Richard Blank
        www.haymakerfx.com
          isn’t that one of the issues that appeared after implementing Adaptive DomeLight? is there a dome in the scene?
          Marcin Piotrowski
          youtube
          CGI OCIO config 04
            Similar to Peter, I can't reproduce the fireflies with the latest builds on our website (although they are present in the 1.1 update, and no, they are not caused by the adaptive dome light).
            If anyone else has issues though, it would be great to provide a scene or some other way to reproduce it.
              I'll upload a scene for you asap!
              Here's a .mov of the issue.
              https://we.tl/t-8sk08bI6Dz
              Richard Blank
              www.haymakerfx.com
                Here's the scene. Warning! It's a big one...
                https://we.tl/t-vFfqxNBu3f
                WeTransfer is the simplest way to send your files around the world. Share large files up to 2GB for free.
                Richard Blank
                www.haymakerfx.com
                  A Falloff map assigned in the Refl. Glossiness is the problem here. I've logged the issue, thanks for the scene!
                  Peter Matanov
                  Chaos
                    Ok that's good to know! So if I remove the falloffs, will the fireflies go away?
                    Richard Blank
                    www.haymakerfx.com
                      I believe so. Look for them in the FP autocreated materials.
                      Peter Matanov
                      Chaos
                        Yes I changed the value to around 0.8 in the second slot and now it renders fine. Thanks!
                        Richard Blank
                        www.haymakerfx.com
